Hej...
Jeg har problemer med at opdatere/redigere i min profil.
Følgende dukker op!??
Error Executing Database Query.
[Macromedia][SequeLink JDBC Driver][ODBC Socket][Microsoft][ODBC Microsoft Access Driver] Too few parameters. Expected 1.
Please try the following:
Enable Robust Exception Information to provide greater detail about the source of errors. In the Administrator, click Debugging & Logging > Debugging Settings, and select the Robust Exception Information option.
Check the ColdFusion documentation to verify that you are using the correct syntax.
Search the Knowledge Base to find a solution to your problem.
Browser   Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.0)
Remote Address   192.38.187.2
Referrer
www.suzukiswift.dk/user_edit.cfm Date/Time   25-Jan-06 12:47 AM
