Repair Instructions
Manual Transaxle Oil Change
S4RS0A5206001
1) Before changing or inspecting oil, be sure to stop
engine and lift vehicle horizontally.
2) With vehicle lifted up, check oil level and leakage.
If leakage exists, correct it.
NOTE:
Whenever vehicle is hoisted for any other
service work than oil change, also be sure to
check for oil leakage.
3) Remove oil filler plug (2).
4) Remove drain plug (1), and drain old oil.
5) Apply sealant to thread of drain plug (1), and tighten
it to specified torque.
“A”: Sealant 99000–31260
Tightening torque
Transaxle oil drain plug (a): 21 N·m (2.1 kg-m,
15.5 lb-ft)
6) Pour new specified oil until oil level reaches bottom
of oil filler plug hole (3) as shown in figure.
NOTE:
It is highly recommended to use API GL-4
75W-90 gear oil.
Transaxle oil specification
: API GL-4 (For SAE classification, refer to
viscosity chart [A] in figure.)
Transaxle oil capacity (Reference)
: 2.2 liters (4.8/3.9 US/Imp. pt)
7) Apply sealant to thread of level / filler plug, and then
tighten it to specified torque.
Tightening torque
Transaxle oil level / filler plug (b): 21 N·m (2.1
kg-m, 15.5 lb-ft)
Med venlig hilsen / Best regards
Thomas Andersen
___________________________________________________
Projekt CarPC               15% DONE
