Hej,
Jeg har ikke testet det, men det skal jeg helt klart!
Det er sgu lidt hemmeligt, men cool alligevel
Nogen der ved om det virker?
Mvh. Morten
Without Using SUZUKI Scan Tool
1) Turn ignition switch to OFF position.
2) Perform following Steps a) to d) within 10 seconds after ignition switch is turned ON and engine stops.
a) Turn headlight switch to “SMALL” position.
b) Turn headlight switch to “OFF” position.
c) Repeat Steps a) and b) 2 times.
d) Press and release driver side door switch 3 times.
3) Check DTC displayed on odometer of combination meter or read flashing pattern of alarm indicator lamp which
represents DTC..
Alt kan fikses - hvis man ved hvordan
